GM 10 Bolt 8.5 8.625 Gears, Diffs, Install Kits
GonicGM
Seacoast New Hampshire
Eaton Positive Locking Differential, 26045476, 28 Spline, fits 71-88, completely deburred case, rebuilt and reset to new factory specifications, sells new from GM for $881, my price $295
Eaton Positive Locking Differential, 12471391, 30 Spline, fits 1988-2003, small hub, all brand new guts, several hundred dollars worth, rebuilt and reset to new factory specifications, sells new from GM for $893, my price $295
Eaton Positive Locking Differential, 12471529, 30 Spline, fits 1999-2007, large hub, rebuilt and reset to new factory specifications, sells new from GM for $844, my price $250
Richmond Gear 4.10 ring and pinion, brand new in box, 69-0165-1, online price $185, my price $155
Yukon Gear, 4.10 ring and pinion, brand new in box, YG GM8.5-411, online price $230, my price $170
New GM 3.42 ring and pinion, brand new, online price $195, my price $170
Motive Gear Master Install Kit, for 1971-2003 GM 10 bolt 8.50" rear axle, small hub, p/n R10RMK, online price $98, my price $85
Images available upon request.
The install kit...what's that have in it and why's it 94+?
The years listed were misleading. I have revised. Thanks for asking. The kit includes all bearings, seals, shims etc., per image. Kit does not include ring gear bolts, axle bearings, axle seals.
Lemme shake the money tree. Going to be putting a Detroit in my rear 10 bolt soon so might be a wise investment.
Are the gears thick or thin for the 10 bolts??
GM/Saginaw/AAM (American Axle) didn't/don't make thick/thin custom gears, last I knew, OEM only. Additionally, I don't believe the aftermarket is making thick/thin gears either for the big 10 bolt, 8.5/8.625.
Except for the GM gears, the p/n's are listed. You can internet search them to confirm application. In lieu of that, I will save you the effort and state that all gears are 'standard carrier'. In other words, require a 2.73-up carrier or 2.41-2.56 carrier with spacer.
I checked and didnt' list anything. I never messed with 10 bolts so wasn't sure. Thinking of going with these just to keep it simple, don't think I'm gonna find a 10 bolt with 4.10s very easily.
Interested in
PMing you in a minute.
can i see a pic of the locker for a 89 model 30 spline 10 bolt what kind of locker is it its not a clutch type posi is it i was thinking about buying a lock right but would this be stronger and would it fully lock like the lock right
This is an OEM non spring preload posi with governor activated locking mechanism.
