Any advice on replacement clutch forks (0.795 FORK ASM., Clutch Release) part# GM 340278-1
there are a few replacement sources--I won't list them
1974 K5 with the SM465 and original bell housing and clutch pedal assembly (nonhydraulic)
also, advice on
doing my homework, what else is on CK5 and elsewhere
Background:
also, advice on
- throwout bearing
- clutch pivot ball
- offset bellhousing pins
- zero on CK5 specifically PN 340278
- most of the CK5 posts on clutch fork are related to NV swaps
- nice informational here on part numbers https://4speedconversions-com.3dcartstores.com/340278.html
- some random discussion on clutch arms here https://nastyz28.com/threads/67-72-clutch-fork-vs-72-and-later.247070/
- a few used ones on eBay for $30
Background:
- Back in 2018, I'd posted about puncturing the pushrod pan on my clutch fork https://ck5.com/forums/threads/push-rod-punctured-pan-on-clutch-arm.334162/#post-3888632
- I'd purchased a new OEM clutch fork but it was in the back of my blazer when someone broke out the glass and helped themself https://ck5.com/forums/threads/k5-rear-glass-no-tint-74.342932/#post-4186107
