Wanting to swap over to the serpentine setup so I just pulled out a complete serp setup from a 454 out of a '81-'87 Suburban, not sure if '88-'91 so I assumed it is the earlier year model.
My current setup has the v-groove belts with the a/c and power steering pump/reservoir in the stock location. Now, this serp setup I pulled obviously didn't have the a/c pump but I was after the 2 piece stamped steel alternator/air pump brackets for ease of installation then I decided to yank out the serp stuff while I'm still there.
But.... those aren't the actual brackets I really wanted.
So....after some hours of google searching, I'm learning that there are the 2 piece alloy brackets (one bracket per side of engine, similar to the '89-'91 350 brackets) that will fit the big block but I cannot confirm if they are OEM or aftermarket. I searched on here first and most threads are from the classified forums, which are of no help.
Anybody out there have this stuff? Post up pics if you can and where did you get them?
EDIT: forgot to mention I want the brackets with the belt tensioner pulley, like the '89-'91 style.
