I saw that on pirate too.
Some research:
If you look at the bottom of
this page it lists four loaded carriers:
[FONT=Arial, Helvetica, sans-serif]
706036-X (3.33 - 4.10)[/FONT]
[FONT=Arial, Helvetica, sans-serif]706037-X (4.56 - 7.17)[/FONT][/FONT]
[FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]706840-X (3.33 - 4.10)[/FONT][/FONT][/FONT]
[FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]706182X (4.56 - 7.17)[/FONT][/FONT][/FONT][/FONT]
[FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]I wonder what the other two are?[/FONT][/FONT][/FONT][/FONT]
PORC's $80 4.56 and up empty carrier matches the 706041x PN of the Dana 4 series case. Randy's also has an empty 4.56 and up case for $90.
[FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]BillaVista also shows only one PN for cross shafts and two PNs for spider gear kits (30 and 35 spline) - I am assuming that would include the side gears?[/FONT][/FONT][/FONT][/FONT]
[FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]Randy's also lists only just three spider kits for the D60, with the only apparent difference being the spine count (30, 32, 35).[/FONT][/FONT][/FONT][/FONT]
[FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]That makes me think that I gould get a 4.10 LP front D60, buy a regular 4.88 gear set and 4.56 and up empty carrier and swap the internals from the old carrier to the new. That allows me to regear to match my rear axle without using a spacer for only $80 more.[/FONT][/FONT][/FONT][/FONT]
[FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]What did I overlook?
