Gm Dana 60 front parts
mudboggink5
NEW JERSEY
Here's what I have
Srw hubs/rotors 200
Spindles 200
Kingpin knuckles 200
Brake brackets 100
Axle shafts complete 275, good u joints
4.10 gearset 50.00
2 sets of manual locking hubs 75 a peice.
All parts located in NJ 07071, I can also ship this stuff, just send your zip.
Call or text 201-468-2168
Warn
Dodge Dana 60
FWIW, that Dana 60 front end is 91-93 Dodge.
spindles same as GM
caliper brackets same as GM
rotor shields are Dodge specific but fit GM
outer knuckles are Dodge and steering arm is higher than GM, steering link may hit GM springs, probably okay with lift springs
Axle shafts, outers same as GM, inners different.
RH inner axle, much shorter than GM
LH inner axle, slightly longer than GM, can work.
I need those bearing hubs if you still have them. I sent you a PM.
OOPS. I just re-read your thread and see that they are gone.
