Did the K5 Blazer come from the factory with an option for the GM Delco CB radio? Where was the CB antenna mounted for these? Was the windshield antenna ever used for the CB?
Are you interested in selling your all in one delco cb radio?Not sure if the trucks came with them optional,but I had 2 of those AM-FM-CB's and one was from a late 70's Caddy,the other from a similar year Olds Toronado...
One of them had a seperate "box" under the dash for the CB portion that was coupled to the dash unit with cables--I sold the dash radio part to a guy at a swap meet who only wanted that part alone,despite me telling him to "take everything"...
The other radio is "all in one unit" ,I still have it,and it works ok,but one channel doesn't play,so its no longer "stereo"--probably just needs an output transistor...
Both units I had,used a "splitter" to allow the CB to use the same antenna as the Am-FM radio..
I was tempted to put it in one of my trucks,but decided I'd rather have a CD player--I have some CB's still collecting dust in my garage I could put in them too..(and police scanners!)..heck,I even have a Am-Fm-8 track thats brand new--I kept several dozen old radios when one parts store I worked at moved to a new location,they let me take the entire "display wall" with the radios and speakers..sold most of them off,kept a few..
Could the cb be run thru a window antenna?
The two cars I got the CB/AM/FM radios from had a factory splitter thing that let the CB use the same antenna ,and I think one of them was hooked to the "in the windshield" antenna too,though I bet the CB performance was less than stellar with that antenna..
I'd sell all of what I have left as far as the radios go,cheep too,because they have sat in my house garage many years since the last time I wired the "all in one" unit up and tried it...still worked ok then other than the dead channel,should still be ok,but who knows.....doubt I'd ever use it ...
..There was a factory setup on some of the early Lincolns that I really liked. I think it was on a 74 if I remember right. The horn button was a rubber ring that ran around the inside of the steering wheel.
It did not stick out, it just felt like a friction ring or something.
But, when you squeezed the wheel anywhere, the horn blew.
I loved it. Not only could you blow the horn without taking your hand off the wheel, but if something bad happened in front of you, you pretty much automatically blew the horn when you grabbed the wheel harder.
