GM ECM 1227747 that has the Moates G2 Memory adapter installed for new 27FS512 chip. Blank Chip included! G2 Adapter is soldered to ECM and cover fits on with chip installed.
This chip can be erased and programmed 1000's of times. Stock chip needs UV erase each time and very unreliable. ECM was tested before and after modification and running in truck for a week. Guaranteed to be good!
1. Will include custom chips for $50. for stock engines with whatever you need turned on or off.
2. Idle set higher if you wish.
3. Auto or Manual trans Bin files are available for 4.3L, 5.0L, 5.7L. and 7.4L engines.
4. Custom chip will include Highway Lean Cruise enabled which is good for 10-15% better fuel economy freeway speeds.
5. Power Enrichment set to 12.5 AFR which will give more power at WOT.
6. Mildly modified engines can be tuned If you can data log with TunerPro.
7. I only tune high performance cammed engines in person sorry!
8. Your engine has to be mechanically sound, I can not tune out vacuum leaks, low fuel pressure or ignition issues...
ECM With Moates G2 adapter and chip $125.
ECM with Moates G2 Adapter and Custom Chip $175.
PayPal or check by mail.
