GM flexplate spacer torque specs?
TruckinFool
Registered Member
Golden, Co
Anyone know the proper torque for the flexplate bolts when using the GM adapter with longer bolts? (6.0-4l80e adapter or LSX-th350 in my case)
Could use the flexplate-TC torque specs as well if you happen to know em both?
Thanks!
Stock flexplate torque specs: 15fl-lb on the first pass,37ft-lb on the second and 74ft-lb on the final pass.
Torque converter torque: 46ft-lb if it was a late 4l60/80
50ft-lb for your TH350
