Or anyone trying to go non egr and doesn't want to buy aftermarket.The 184 intake was in fact the factory intake for 1969 vehicles, 350” engine. It is common to the cars as well
only legitimate reason to keep it is if a person running G/SA or H/SA in NHRA Stock Eliminator (Camaro) wants it, or a numbers match guru
I never pretended to know about this, I was always the cheap guy getting things done with available parts.Meh. Aluminum ones are $40 all day long at the swap meet with an egr block off. They all run better than these.
we flow benched 14 of this exact number. They are all a turd
So you're saying that holding onto the one that was originally on my Dad's '72 C10 is not a good use of space?Meh. Aluminum ones are $40 all day long at the swap meet with an egr block off. They all run better than these.
I have always been a firm believer in putting studs instead of bolts on the thermostat housing and carb base. It makes for any water neck/thermostat/carb work in the future a lot less troublesome not having to worry about broken bolts.I might put this one on my burb.
I have the original 77 non egr cast iron on it now.
My only hesitation is adding aluminum into my cast iron, brass, only cooling system.
I don't think bolts are his problem hereI have always been a firm believer in putting studs instead of bolts on the thermostat housing and carb base. It makes for any water neck/thermostat/carb work in the future a lot less troublesome not having to worry about broken bolts.
Looks like a golf ball stuffed in it and wrapped with duct tape.
I guess on my phone I can't see that much detail but now that you have said it, I can see itLooks like a golf ball stuffed in it and wrapped with duct tape.
