mudbog42
Ok well here's the deal, trying to get a/c working again on my 99 Monte Carlo (3.1l).
When I check the system pressure it shows that it is full
, but the compressor clutch does not engage. So I jump 12 volts the compressor and it engages, so compressor and clutch are good I'm assuming.
I checked the HVAC fuse and its good, then I replaced the a/c relay and still nothing, so I figured it has to be the pressure switch...well just replaced it and still no go.
Even with clutch engaged though, it doesn't blow any cold air and the lines under the hood don't even get cold.
I can't seem to figure this out, any help would be greatly appreciated
