Hello, everybody!!!
The block from the previous owner had "fixed" a bolt hole that cracked or something. It was "filled" with something. The outer most bolt slot for a staggered starter pattern.
The one on now is able to be clocked. Now, will one of those screws on the front be able to be used for a GM starter bracket?
I know I know, some hate them, some don't even know about them, and some don't care about that bracket. I on the other hand would like to use one, these starters are heavy and in an already compromised part of the block, if like some support on that beefy starter.
Do I have to remove the starter to clock it or can the front be turned to get one of the screw closer up top.
Google image of what I'm talking about. Notice the portion to attach the bracket very different than what I have on the truck now. The mini starter I ordered was dead out of the box and past return window, shop installed this one as it's local and easier for warranty. Bla bla Bla.
Starter on the truck now.. I assume the 3 allen type looking bolts are unscrewed and the starter can clocked that way?
