pauly383
Daddy383
No shipping on heavy stuff LOCAL ONLY , unless you pay exact freight and I can only make it to the UPS store on the way home each night .
Cross posted to local board too , first poster(s) based on time posted gets part , then continue on the line .
Factory air cleaner housing and tubing for 1997 Vortec 350 - make offer
Pre 1974 heads one 487x and one 993 , 1.94/1.50 , need cleaned and built , heavy castings with flat edge by lower bolt holes - 100.00 each
624 heads 1.94/1.50 , lightweight castings , dirty from sitting outside , pair 50.00 each
400 CRANK , looks nice , never mic'ed it , probably stock size ( I will be getting a new kit in a couple years ) - 100.00
3970010 block 4 bolt , .030 over , two pistons went south , will need to go over at least to .040 to clean up , Good main bolts . Cam , Mains and rods bearings were gorgeous - make offer
good smog year quadrajet - 50.00
good pre smog quadrajet - 50.00
1 inch zero rates and bolts - 50.00
78 Suburban good body with title , front clip from another rig for it rigged up with roller half tons to move . I am taking shortblock out and steering column , good glass except windshield - 100.00
Factory 70's rig tow hooks - 30.00
Computer controlled large cap HEI distributor , no provision for advance of anykind , looks like pre 87 TPI or crossfire - 50.00
Grey 80's Mustang cloth with lumbar seats - 20.00 each
203 for parts - 25.00
sm420 , sat outside , real low gear - 25.00
second battery tray for GM trucks , think 80's - 25.00
