gm van d60 dhd?
Well in case you didn't know, there are companies that build 4wd vans out of Ford axles, most times they use D44 but occasionnally they use D60 which this one is.
Why the guy called it K5 though is a mystery to me.
Usually it's either K20 or K30, at least the companies that I know put those stickers on them.
Yeah I've seen them before.I like the twin front pumpkin ones, petty neat. Would it be gm spring spacing I wonder. Would be good if engine swap required dhd xfer case.
Yeah they used the same spacing I believe it was 32"
The dual pumpkins ones were a little goofy, but they did that to keep the van low and had the engine oil pan in between.
