Wyomingboy
Guys, I am wanting to put a crate motor in my 90 blazer with TBI. I have found a place in California called TurboCity, that modifies TBI systems for higher flow and burns the chips for the computer to work with any of these higher output engines originally built for carbs.
I am thinking of either the GM Performance Parts HT383, which has a great power spread and 435ft-lb of torque or the less expensive 350 HO, which has 330HP & @ 370ft-lb of torque. Both of these motors will need TBI work from what I have been able to find out.
I mainly want a motor that will pull overdrive with stock gearing & tires up the long grades we have in the mountain states, without excessive(or any?) shifting.
So does anyone have any experience using either of these two motors in your Chevy truck?
Thanks & regards,
Wyomingboy
Thanks & regards,
Wyomingboy
