To start I know very little about GMT400 trucks. I bought a 98 C3500 parts truck. I'm hoping to use the engine and trans. I'd like to test drive them but the gear selector is broke off. I've never been into one but it looks like some of the cast metal pieces in the column are broken. I think it's probably beyond repair short of replacing the column.
There seems to be a cable between the column and the trans. Is there a place I could disconnect the cable in the cab and then use a couple of pliers to operate the gear selector on the trans from the cab?
How is the cable routed?
