Gmt800 alternator
Wes Harden
1 ton status
Staff member
Moderator
Solutions
Lake Havasu City AZ
Today the batt light came on and stayed on long enough for me to get home and do some testing. Running on batt voltage when checked with a multi meter, dash gauge agreed under 12v.
Wiggled the small wire connector and bingo the voltage crept up to 14ish volts.
2 questions. What is the series name for these alternators ? Any one know the terminal size or female pin part number ?
the 130 amp on my truck is the AD244. and the terminals are Metri Pac 150. I think, I'll know for sure when they arrive.
I assume that you tried to tighten the terminals up for a better bite on the blade/male side.
I wonder if the terminals have gotten cracked loose inside of the regulator.
I'm going to play with the old one, once the new gets here. I ordered a new plug, the terminals do look much smaller than the old one. While trying to depin the 2001 plug it broke, new one was needed.
