Going Hybrid!!!
Mudzer
Author
Missouri
Well, this past weekend's snow run was the last I'll take in my bulky K5 - 'Tis time to trim the phat!
I've located a couple of S-10 Pickup Cab's and have begun the thought process of how this rig will turn out.
Tyler Birkey knows eeezackly how I will build it too! Ever since I saw Beau Byrom's rig at Mudstock, I have flipped through the many pics I took of his rig. He has since rolled this beauty, so I'll steal his concepts and take them a little further! Here's a pic of Beau's rig, shortly before the roll!
http://www.4wheelingplus.com/images/Pic-6.jpg
He started out with a 2+2 1 Ton 4x4 and shortened the frame - I'll be using my current frame and drivetrain. He installed a clean S-10 cab on the frame and hacked out the front portion of the fenders. I might steal some ideas from White Knight for the front tubework. The cab sits nearly perfectly centered front to back on the frame. There will be an intergral roll cage inside the cab. Planning on welding in the "Watson Console" look as well as the "V" uprights in between the A-Pillar (like Watson's). It will likely get Half-Door treatment someday.
The rear bed section will be made from Aluminum Diamond Plate and will be covered by a second roll bar/cage that coveres the fuel cell, tool box and cooler storage.
Overall, I think this will be much more fun on the trails. I will also lower the truck a little to keep the CG down for uphill and offcamber situations. It will be leaf sprung for the first building stage. /forums/images/graemlins/grin.gif
Frisbie - get that garage cleaned out, we've got some tubework to do! We will work out payment arrangements later /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/rotfl.gif
Will Work for Fabwork....
I thought you would say you were going gas/electric.
have you seen that what-ya-ma-call-it kit that bolts on a frame like yours. Can't think of the name right now...but it is a buggy-like setup w/ four seats, a full body, yet huge tire clearance. Just a thought.
Ernest
Yeah, but I'm keeping the whole GM theme brother! /forums/images/graemlins/thumb.gif
Yeah, that was a hell of a rig, cant beat running 44s with NO LIFT, having awesome visibility, and much less weight.
Tyler
No way I can be sure at this point. I'll get numbers prior to and after the swap!
The key is, I will be saving weight and having a lower CG.
[ QUOTE ]
Tyler
[/ QUOTE ]
at some point you want some lift to get the junk off the rocks.
4-6" lift with 44's will get the belly up and keep the firewall from interfearing.
Or, you could build a custom doubler (I did) and get a flat belly pan and gain that 4-6" back over a standard doubler. How much does yours hang down? /forums/images/graemlins/grin.gif
I will leave my current 6" lift intact for a while, then see about removing leaves to soften up the ride. /forums/images/graemlins/thumb.gif
Think about it, he would have about the same frame to ground clearance as say a truck with 4" lift and 37s or so, plus with the s10 body i dont think he had any problem with firewall clearance.
s-10s are small inside... why not go full exo instead of full internal cage? thats what I plan on doin when i go s-10. At any rate, good luck... and take LOTS of pics of the build-up. /forums/images/graemlins/grin.gif
j
[ QUOTE ]
[/ QUOTE ]
What are people paying for s-10 cab's? I might go this route to shed some size and weight.
Hey,
Taking leafs out sounds like a good plan. IT will give you a long spring with lots of droop. How low can you really go with your current steering setup ?? Anything below four inchs and maybe a flatter draglink would be used, then maybe a different engine crossmember to clear a flat link ?
How did that guy do his steering ? With stock leafs, i dont see room to do crossover. And with the twisty trails in Fulton and such, you gotta have it.
Let me know if you will be around friday night or saturday.
Blake
pix and pix and more pix... especially of how you solve tradition going-hybrid problems like custom body mounts, front clip mods and all that jazz. /forums/images/graemlins/laugh.gif /forums/images/graemlins/thumb.gif
j
Good luck! You will be happy when you are done. Couple of hints- make your own body to frame mounts (don't bother adapting to your frame, saves time), use a Sub frame (straight and light)if you want to lengthen wheelbase (I used Blazer frame with S-10 Blazer body, my brother used Sub shortened to 115" with S-10 Ext. cab, I wish mine was that long, it makes difference), if you keep S-10 core support you have options for smaller and lighter radiators (check JTR.com), I would do exo cage (more room inside and offers body protection from pesky rocks, and take advantage of body off frame to any chassis mods (sooo much easier).
