Hey all. My '73 K5 is so rusty that it's beyond repair. I found a great '74 body on Craigslist and if everything goes according to plan, I will pick it up this Sunday. The body I am getting is strictly sheet metal, no trim, dash, anything. Just the tub. So I am going to have to strip my existing body, get it off the frame, put the new body on, and begin reassembling EVERYTHING. At the same time, I am going to install a painless wiring harness I've had on the shelf for 7 years.
What I would like is some advice from those who have done this before. I have no hoist other than an engine hoist, so the actual removal of the old and install of the new is going to be using muscles, levers, rollers, whatever it takes to pull one off and install the other.
It seems, ideally, I would just remove everything from my K5 that ties the body to the rest of the truck, ie. wiring, steering and shift linkages, gas filler tube, heater hose, etc., then remove the body. Put the new one on and start swapping parts from the old to the new. However, in the interest of removing as much weight as possible, to make moving the body's easier, I think I will need to completely strip the old body, before I get it off the frame. Then, hopefully with the help of a multitude of 8x10 color glossy photos with circles and arrows and a paragraph on the back of each one, remember how all that stuff goes back together once I've got the new body on the old frame.
I live four blocks from the ocean, which is why my K5 has slowly disintegrated into small piles of rust in my driveway and on my floorboards. The body was in bad shape to begin with when I got it 12 years ago, but all the bad crap had been cleverly hidden by judicious application of bondo and a fresh-ish coat of paint, by the PO, or PPO....who knows..
What can I do with my new body to keep the rust from taking hold. According to the guy I'm buying it from, the only rust he can find is at the bottom of the pillars where the tailgate attaches. I want to make sure I stop this infection, and protect the body from additional rust infection. Would a coat of rhinoline or something similar on the floor from the bed up to the firewall be a good idea?
Has anyone done this before? Where did you start? Should I go in any particular order?
Some pics to show how bad my poor K5 is looking...
