ccarley
The 10 bolt in the back of my '89 Suburban is clunky, howling slightly, has a gov-bomb, and the pinion seal is leaking.
In my search for a new/used rear axle, I found one down the road from me taken out of an '82 K5 (supposedly): a 12-bolt with the same gears.
It's already pulled from the truck, and is super cheap.
I do have a couple of questions though. Will the spring perches be in the correct spot for my Suburban? I would imagine they are, but just wanting to check. I'll be bringing my tape measure with me when I look at it too.
What about the brakes? Will the brakes from the earlier K5 work fine for my Suburban? Or, would my current brakes, from the 10-bolt, swap over to the 12-bolt?
Before the axle goes in, of course I'll be freshening it up. Probably installing a locker of some sort. I'm not "hardcore" with this rig, but having a rear locker in the snow and mild mud that we see really helps.
Now, I realize that nobody really recommends the 12-bolt as an upgrade to the 10-bolt. But, I want to keep my 6-lug pattern right now, since I just bought tires a few months ago. It will help keep things simple. And, for the price of an axleshaft, I'm getting the whole thing, where my current 10-bolt needs bearings, shafts, seals, etc.
Thanks for any advise in advance!
Clay
Clay
