79k20350 said:im not a much of a turbo go but i understand the principles... when you say exhaust side, do you mean where the exhaust enters, or exits? if its where its enters it should reduce lag time (one would think) because you have a better flow...hmm...then again smaller might crete more exhaust backpressure making it spool the turbo faster... hmm...we need someone int he know to explain![]()
That is exactly how it is:
the smaller turbo exhaust volume requires less exhaust to pressurize thus spool faster.
Also the trick about triming the vane fins on the compressor side makes for less of a seal which makes less oposition on the exhaust side which makes it spool faster then the faster vanes can compensate for the lack of pressure at lower speed.
