NOT AVALIBLE ANY MORE SORRY .
i have a ford divorced 203 range box thats little rusty but very solid on the inside. nice n tight no major chunks / chips / play. the syncro theeth are real nice shape and all other parts removed were real clean . betting it was a low mileage box but it lived its life up here in the rust belt. had to cut off bolt heads for the gear case to chain case to split. so bolt flange areas need little rework .
its a 32 sline input with u-joint yoke and flat face you could drill your own pattern into if you wana make it bolt up to a tranny . but would need to swap input gears tho.
i also have a N.O.S large bearing 205 case empty with new short 32 input gear/bearing and snap rings. for the right price if you wana make a divorced doubler or reg doubler with your adaptor pattern drilled in the 203 face.
