Sold Gone
nvrenuf
Holy crap, it's running!
Mobile, Al.
----- SOLD -----
These are factory power mirrors found on 90-91 Blazers and Suburbans. I've tested the mirrors and they do work in all directions, the switch is unknown (mounting pegs broken).
These are used and have scratches, 1 miiror has broken glass.
$60 + freight
full
full
I have a question, I'm trying to understand the wiring a little bit. How does the switch connect to both mirrors? Does the switch go to the driver mirror then there's a second jumper that reaches to the passenger (which I'll probably have to fab up)?
I just wanna get as much info as I can before I try this swap lol
I'm sure it's technically a separate harness but it's all bundled / taped together with the power window / lock harness. There's a small pigtail that runs from the main bundle to each mirror and the one switch. Once it comes inside via the left door jamb it gets lost in the dash wiring but certainly runs across to the opposite door to power that mirror.
Do you still have these? I'm pretty interested in them, can you adjust the mirror by hand? If I wanted to wire them in on a later date.
Yeah I've still got them.
When I replaced the glass on the mirrors on my blazer I pushed them around some but I haven't tried to do it a lot. Maybe once to get it set in position but I wouldn't do it a lot, it might strip the mechanism.
Found them on the porch this evening, my kids loved the packing paper in the box.:waytogo: Thanks again.
