Good 465 clutch linkage
someone has pics in the garage i think of hiem joints and threaded rod to upgrade it. search .
if need be i have a setup i can check. from when i went hydro.
What parts are you looking for? I've got a couple complete linkages--do you need the pedal as well? I know I had to replace my pedal because the bushings wore out and the pivot shaft wore almost through on one end. Let me know what you need . . .
I think he could use all the linkage and the Z-Bar.
