Good line lock?
carpeonnel
Sylvester, Georgia
wanted to see if any of you guys running line locks had a good line (no pun intended) on some. Also I was planning on hooking them up right after the reservoir. where do yall have em? got any pics?
I have the Jegs brand one on mine, it works fine. Its mounted on the engine crossmember I think, by the junction block/proportioning valve thing.
are just running a single lock for the rears or are you running one for the front as well? I figured I might as well put 2 on to lock all 4s if I wanted to
I'm running the Jegs brand ones as well (not sure which company makes them). I have one on the front brakes and one for the rears, mounted on the driver's side inner wheel well.
I use them frequently whenever I take the truck on the trail, though unfortunately that isn't nearly as often as I would like, but after several years I've never had a problem with them.
I see everybody running hard lines to and from a line lock, but would there really be a problem with running some stainless steel flexible ones?
well that was my original plan but I got looking around and realized I have some spare stainless brakes lines I got a long time ago I never used. figured I could save some time and money by using them instead of having to cut and flare a bunch of lines
