Good news
C1090blazer
richmond missouri
im getting my 3/4 ton axles sunday dana 44 8lug and 14 bolt full floater ....i have a couple of questions ....does anyone have a picture of a full floater 14 bolt of the drums...because i dont want to get a dually rearend .....and what do i need to do a swap for a 14 bolt full floater .......
No Dually?
Sorry bro no pics for you. Pirate4x4.com has a fully detailed with pictures in the 14bolt Bible, with tons of pictures. First off , if its going into a blazer the spring perches are first to go as they are not the same distance apart, also shock mounts are not compatible. RuffStuffSpecialties.com, has 2 great kits to ease your installation woes,a simple swat:perches, spring plates,u-bolts,and nuts, as well as sidewinder shock mounts, there is a more in depth kit they do also:including the above plus a gnarly 3/8 thick cover, a beefy pinion guard,and caliper brackets for any of the 14 bolts with whatever hubs you have or plan to run. I am partial to ruff stuff as they are local, they build top notch pieces, and if they dont have quite what your looking for they will absolutely have something that will work,talk with Dan. They are always looking for new part ideas , so drop them a line. Before you decide on DRW SRW, or van SRW, consider what track width you want to end up with. Check out the 14b bible, then make your own call. Good luck
