Good tire combo? help!
tyler__820
St. Helens Oregon
So i am in the market to buy new tires and i have a few questions!
1. i want the 39.5x18x15 boggers out back but as for the front i saw that they have realeased the 40x16x15 ltb. so would that be a good tire to put up front or do you think its to grabby and will break alot of parts? should i stick with the 39.5x15x15 regular tsl?
2. what size rims should i use for those tires?
3. does anyone run the 40" ltb or a combo like that? i would like to know how it works!:confused:
tahnks for the input guys:bow:
Just make sure the tires are close to the same diameter on the front and rear. Much more than a 2-3% difference can cause damage to the 4x4 components. Even comparing two different tires from the same manufacturer (like 35" boggers to 35" TSL's) you will find they are not the same diameter.
Well my stepdad has the 39.5 boggers and tsl'd but the boggers look a little bigger then the tsl's and im not sure why. could it be because of the width of rim he is using?
Look for a 15x12 wheel. And like previously mentioned the different height can cause problems when 4 wheel drive is engaged.
Why not just run all four the same? The manufactur will have suggested rim specs. I say the smaller the rim the better for offroad!
Allot of guys that run only mud, run Boggers in the back and TSL's up front for steering controll. A TSL steers better than a Bogger
If you do decide to go with 39.5x18x15's & 40x16x15's, you can play with the air pressures to get the heights colser together.
