Goodwrench 350 tbi
keevy
Belgium
Is a new Goodwrench 350 TBI engine a good engine to replace mine old engine? Other options?
Thanks allot
Yep, I did the same thing. I havent have the slightest problem with it yet. I was thinking about an upgrade to a higher HP model at the time, but I chosed the factory reman.
If I were to do it again, I probably would have chosen the higher HP from an aftermarket, or GM performance line, but I was not planning on offrading the Blazer then. It depends on your needs and wants.
But all around value, warranty, and avaiability, I would say yes.
Stock engines are ok but if you want a little more HP check out cfm-tech, the make a kit so you can run tbi on a GM 330hp crate engine. A little more expensive but not a bad deal, thats what I am going to do when my stock engine gives up. Plus I am running there throttle body and some other stuff and love it.
Thanks allot
Well mine wasn't a TBI engine but still a GM Goodwrench. 290 hp with headers and 650 carb plus and Edelbrock Intake. Wasn't bad in stock form with the carb. Once I fuel Injected it, WOW. I found great turn key deal on nmine at Pace Performance on the web.
