red EOD
I did some bastard axles like that on a mini ex trailer when I was with the power company in Moab. They drug the thing over some boulders and mangled the axle tube twice in a row so I stepped up to like 5k tubes and kept the lesser rated hubs so I could run the same tires/wheels. Didn't need to go higher on them since all it ever hauled was a 4,500 lb mini.
I like those junction boxes. The clear versions are nice to if you want to be able to glance at it to see if things are getting green and fuzzy inside but they don't stay clean if mounted under the rear of a truck/trailer.
Agreed the electrical boxes make diagnostics and changes much easier.
Gonna be moving back to Texas in May to work in the oilfield again and start building on the property at Lake Brownwood. The tow rig is ready however the trailer needs a few things for a long trip like that. 2 loads for certain, maybe 3 if I can't pack it down well enough/sell things. As it sits is 1 load all by itself.
Ordered:
1 new 5200 lb axle with brakes and standard 6x5.5" hub pattern to replace the front axle
3 new wheels for that pattern
4 new tires
New marker lights for the sides
Other repair needed is the brakes on the 1 axle that currently has them. Had thought about going to a new 14k rated 20ft trailer but this one fits my "little trailer" needs well. Bit of a diet with the current stuff needed but that shouldn't be difficult.
