breakthru62
Registered Member
Hi Guys! I'm a newbie and I really could use some help trouble-shooting.
I have an 80 Blazer: 4x4, 350, Auto trans (will post model tomorrow).
This Blazer is mostly stock, but I think it has a slight lift (will post specifics tomorrow).
Anyhow, I'm having a couple of problems. My rig will fire right up, but when I come to a stop, the motor starts ideling eratically. It idles where it should, but then it drops to the point I think it's going to die but then the idle goes back up to normal........up and down........up and down. It doesn't always do this, but it's becoming more frequent. Anyone know what might be going on here?????
Another problems is the tranny. When I start it up in the morning and put it in reverse from park, it doesn't engage. However, when I shift from park to drive and then to reverse, it engages and I can move. It also shifts fairly hard sometimes making a loud 'klunk' sound. What's going on here????
Also, I have a "squeak" coming from the rearend. The squeak is only present when the blazer is cold and going below 10mph (at least I can't hear it). For instance, when I back out of the driveway in the morning, the squeak gets higher and higher (the faster I go) but goes away after I reach a certain speed. I haven't noticed when taking of from stop after driving for a few minutes. Got any ideas???
One last thing.........My dash lights aren't working, but the blinkers and highbeam indicators are. I haven't checked the fuse yet
......could this be the problem??
Any and all help is greatly appreciated. I hope you guys can help.
Thanks,
Scott
......could this be the problem?? Any and all help is greatly appreciated. I hope you guys can help.
Thanks,
Scott
