I spent the weekend getting the engine back in my blazer. I pulled it because my oil pan was leaking and needed to do a few other things to the engine. This was also a good time to put in the diy 4x4 engine crossmember.
The first question has to do with the cross member. How did you guys get the engine in and lined up with the bell housing and over the mount at the same time? I think I did it wrong bu I had the crossmember all bolted together, mounted the plates on the engine and tried to slide it over. That didnt work so I took the plates off the engine and got the engine in position. Then I had a hell of a time bolting the plates back up. The only other way it looks like you can do it is to bolt the cross member to the engine then set the engine and bolt the cross memeber to the plates the go on the frame... Hey I dont know alls I know is it was a pain to get the engine in.
Second question, I have been fighting a power steering issue since I put the truck together. I have cross over steering and I have been too cheap to put hydraulic assist on it. Anyway I have gone through so many pumps it is rediculous. The last one I put on was an AGR pump and it seemed to be doing great. When I was mounting the pump yesterday, I put the pulley on and I noticed that the shaft had some in and out play as well as up and down. I am afraid this one is getting ready to take a dump. Any one else have steering issues like this when going to crossover? I guess I am going to bite the bullet and put hydro assist on.....
Thanks in advance
Thanks in advance
