hunterguy86
I'm working on an '89 Ford Super Duty. It's a brush truck for our Fire Dept.
The truck has a 460 with the ZF 5 speed standard.
The clutch went out on it. I replaced the clutch disk, pressure plate, throw out bearing, pilot bearing, slave cylinder, clutch master cylinder, and the hose connecting the two. I bled it like crazy and get good fluid when I do. However I still get hardly any pedal. It drives ok but the gears grind due to a low pedal. I need to get this fixed ASAP as it is a fire truck. Anybody got any advice?
