so what do I need to look out for?
As always, thanks in advance.
Well, I've been doing my homework. I see no way for a 6.2 to haul a 25 foot travel trailer without being the slowest vehicle on the road.
I need a plan B...
Hmmm...lateral shaft play is actually normal for a turbo. Once the bearings pressurize with oil the slop is taken out. Spec on a Banks is between .010"-.018" side-to-side play. Basically as long as there's no housing contact you're good.side to side wobble from the turbo vane is the big killer
GotchaYeah. It has a th400 in it already, so I'm use to that. Plus, I would have much more peace of mind with the 4l80 for towing. Might even try overdrive on the flat portions...
Fore-to-aft play is actually the critical one - somewhere around .003" max. If you can feel it, it's too
That's what I was trying to say...but I was holding the turbo the other way when I typed it
I would jump on that humv setup. You'd be hard pressed to loose on that
I retained the mechanical pump when I installed the Banks on my pickup truck...it worked fine until that first pump failed. After that I put an oil return nipple on a block-off plate and have been running an electric pump ever since. Side benefit: super-easy priming of the fuel system now.Lemme know how you fab up that oil drain. I don't think I've seen anyone try to keep the mechanical pump when adding a turbine drain in that spot.
he took the mechanical pump off and put a block off plate with a return nipple on it...like this
