OK, I had a cookout and dove shoot to go to this afternoon, but a friend's power converter/battery charger on his camper had bit the dust and I was trying to get it going beforehand.
The cookout was at his camper, so that helped a little. I had checked the unit out yesterday, and the main fuse on the board was blown.
He said the camper had taken a lightning surge, but that seemed to be the only problem.
Darn fuse was a solder-in pigtail type. Normally not a problem, but I was at the farm.
So, bright and early, I hit the road in the M-class to try to find a fuse. I had no chance of finding a solder in, so I was looking for a 250volt 15 amp glass cartridge fuse and an in line fuse holder.
Finally found one at a hardware store across the river bridge. The fuse holder I got at an automotive store.
I was headed back. I figured I could solder the holder on the board and put the fuse in.
But, I remembered I needed cat food. Swung by the Dollar General to get a big bag of the cheap stuff.
Hey, they are cats. If it were a dog, I'd get the good stuff. These cats can take what they get and like it.
If they don't, there are lots of rats around the farm.
Pulled out of the parking spot, feeling good. I had all the parts, I was way ahead of time, and everything was lining up.
Suddenly all hell broke loose under the car. LOUD grinding ringing sound. I pulled over in the parking lot, and got down to look. I was hoping I had picked up a piece of steel wire on a driveshaft or something.
Did not see a thing. Go back in and tried backing up. Same noise, no change.
Hitting the brake did not change it, so it was not a brake shoe problem. Turning the steering and driving in circles changed nothing, nor did kicking the tranny out of gear and coasting.
After looking under a couple more times, I had to make a decision.
It was about 15 miles back to the farm, but about 3 blocks to my mechanic's shop.
He was closed, but I figured I could creep there, park the car and call someone to come get me.
When I got home, I could get in the truck, go back and get my stuff out of the car.
I had a laptop, rifle, pistol, shotgun, and lots of electronic equipment in there that I did not want to leave over the weekend.
I turned on my E-flashers and started down the highway at about 25. The noise was almost enough to set my teeth on edge like nails on a chalkboard.
And it was getting louder. People were turning around and looking as I drove by.
Suddenly, just as I was signaling my turn into the shop, it went "PING" and the noise stopped!
I got into the lot, climbed out and looked under again. Still did not see anything.
The car is just too low for me to crawl under.
I drove back and forth, turned circles, no noise.
At this point, all my years of mechanical knowledge, common sense, and general smarts flew right out the window........
I thought of all the stuff in the car, all the things I needed to do, what a hassle it would be to come back and unload it all..............
Its only about 15 miles............
Its not making the noise any more............
If something goes wrong, I can walk 100, maybe 150 yards.......
It would be incredibly stupid to try to drive that car home. I am IN THE MECHANIC"S PARKING LOT!!!
Yeah, I did............
I visualized the drive home, and worked out about where the halfway point was.
I eased out of the parking lot, pointed the nose West, and started out.
Windows down, radio off, listening for the first hint of a grinding noise.
Chickened out at 50mph, locked the cruise control in at that speed so I would not go faster.
Hit the halfway point, no noise, kept going. Stupid car never made a strange noise all the way home.
Its parked until Monday or Tuesday. I'll drive the truck into work Monday, probably take Tuesday off and see if I can get the car back to the shop.
Still cannot believe I did that. If you could have heard that noise..........
At this point, I am beginning to suspect the rear driveshaft saddle bearing. Why it even has one I have no idea. The rear shaft is about one half the length of my truck, which does not have one.
The rear diff is bolted directly to the frame, since it has independent rear axles.
The drive shaft is a straight line to the diff, with no flexing over bumps. But, for some strange reason, they have a saddle bearing about 8 inches from the rear end.
It went out once before, and I seem to remember it made a similar noise.
I'll post a final result when I find out.
