Got KC Hilites on EBay... am I missing something related to the mount?
garydan
Port Saint Lucie, Fl.
Take a lookie here:
I don't have my bumper yet, but its coming with light tabs. I'm assuming the tabs go in between the two rubber discs. But even if I tighten them down, the light would still wiggle. It's as if I'm missing a piece between the light housing and the top "mounting disc".
You are correct, you are missing the pocket that goes to the swivel on the bottom of the light pod.
back in the day walmart use to sell a 2 pair pack for under 50 bucks. i grabbed a black set and chrome set.
few months later thay went up to around 100-120ish. should of grabbed more when thay were cheep. :doah:
If you have a welder just make a spacer. Just get the correct diameter of pipe and cut it to length, I would guess around a 1/2" just looking at the picture. Weld a washer on the bottom side with the correct bolt hole size. On the top side where you need the pocket for the housing to swivel in place a finder washer dead center on the pipe and smack it in the center with a ball ping hammer to give it the dish. Then weld it in place and clean/trim it up. Not as fancy as an aluminum spacer but it should work.
I have an old one with a broken lens and peeling reflector. I can check and see if it has that part if you want.
i bought mine from a local guy for 10 bucks. his truck came with them when he bought it and he couldnt fit under his car port lol.
