I am about to get my two post lift. I am getting a Challenger E10 installed by a professional. I have NUKED the two vs. four question for months, it's decided. The E10 fits my needs/desires perfectly, and it was highly recommended by the installer, who also distributes/sells almost any brand.
I just wanted to know if there were any lessons learned that I might not have considered. I am specifically concerned with placement within the shop. I have a 30x50 shop with an 18' wide door on one of the 50' sides. That door starts 6' from the end of that 50' wall. If you are still tracking, picture standing in the middle of that 18' door (so you are 15' from one side of the shop, looking at the back wall 30' away). Look about 15 degrees to the left and I was thinking about placing it at an angle so that you pull in, to the left a bit and drive right between the posts. Basically, draw a straight line from the center of that 18' door to the far back left corner of the shop, the posts would be out on either side of that line. I would like to place them as far back as I can in that corner because I also keep my '88 K5 and my '72 C20 in the shop where I am building (well, going to build) my '72 K5. If that made sense, right on! If not, I can try to clarify.
Any thoughts are appreciated.
