elks
So I eventually won the contest but not after I few choice words (said under my breath so students could not hear)
. We are currently taking down our dana 60. today we were on the last steps of pulling the knuckles off etc. the tops were a piece of cake... But the bottom was a different story all together
the lower cap was stuck on. the build thread we were using as a guide said just take a screw driver and hammer tap it in and wedge it off. Well The first one came off after 40+ minutes of whacking. It took chisels, 3 screw drivers, a 4 pound sledge.... It also meant beating my finger a few times (insert the choice words under my breath here). I then went on to the next side... My for arm was burning/elbow hurting (baseball just started up and I am a coach)...
I had sweat dripping and began the next side. Same issues. After about 30 minutes I gave up for a bit... the kids all gave me crap, so I drank a mountain dew for that popeye effect. And in 20 minutes had the second off.
So then I once again made my students
to me...
In the process I chewed up the edges a bit. If I just touch em up with a grinder will they be OK to reuse?
Also how can you tell if you need to replace the actual metal king pin tapped top with the big allen? My plastic bushing is messed up on both sides so they need replaced.
. the lower cap was stuck on. the build thread we were using as a guide said just take a screw driver and hammer tap it in and wedge it off. Well The first one came off after 40+ minutes of whacking. It took chisels, 3 screw drivers, a 4 pound sledge.... It also meant beating my finger a few times (insert the choice words under my breath here). I then went on to the next side... My for arm was burning/elbow hurting (baseball just started up and I am a coach)...
to me... In the process I chewed up the edges a bit. If I just touch em up with a grinder will they be OK to reuse?
