Got my new driveline
4xmac
Calif. Oceanside
Well got my new 1 ton with 1350 cv driveline yesterday from Jesse at High angle. I should also be getting my front 1 ton sometime this week also. Jesse did a great job, excellent craftmanship. Thanks Jesse
MAC
Is it in yet? What transfer case are you running? I am almost done with my NP205 conversion from slip-yoke to fixed yoke and am going to get one of his 1 ton cv shafts. Also how did you measure for proper length? Sorry for all the questions.
If you didn't build it yourself, how can you call it yours.......?
Leadfoot, I just got installing a 205 t-case. In order to get acurate measurements, rotate the rear pinion up to where the yoke is pointing up at the t-case. Then take a measurement from the center of where the U-joint would sit in the yoke of the t-case to the center of the u-joint of your rear diff. You"ll love your driveline. It"s beefy.
MAC
