Got my truck alittle dirty last night
I should have got some photos of the under side of the truck. After I got the under side of the truck clean I could have went mudding in my drive way. When I get my dana 60 installed I will get it nice and muddy. 36 swampers and a 3/4 front ten bolt dont mix. I hardley even got to play I spent most of the night be a rescuring toyota's jeeps's and I cant for get how many times I pulled out fords because they thought they were the $hit and they were all show but no go.
nice truck what you got in/on it? /forums/images/graemlins/truck.gif /forums/images/graemlins/cool.gif
All the mud is caked on the under side of the truck and in the wheel wells. IF I had wider tires it would have been allot more mudd caked on the body.
My truck has a 350 horse gm crate motor. IT used to be a 6.2. It has a th400 with strait cut gears and a lower first gear. For t-case it has the 208. The rear is a 14bolt
the front is a 10 bolt. Soon I will have my dana 60 under the front once I get the steering block and the u-bolts.
Nothin special just a fun truck to drive.
BY the way don't those 36 inch tires look small. I am going to up grade to 38.5 or maybe 39 when I get the 60 in.
Maybe you just need to put your foot down. My tires are completely covered by the body and I still managed to cover most of the body, the entire under carriage, and the engine bay with mud.
Mikey
