got rockwell?
cybrfire
1 ton status
Iowa
All you need to add is a Chevy 3/4 ton 4x4 loaded caliper and your good to go. Err, stop.:D
$112.00 and can ship in a large flat rate box for 12.95. So to your door just under $125.00.
Formed and braced bracket (NO SPACERS), rotor, pinion adapter, pinion cover and hardware.
Couple days and these will be up on the website. If ya need to order sooner than the website update, call the shop and we'll get them on their way in short order.
sweet. What are the rotors? wilwood by chance? I wanna make sure they are easy to replace.
Have you tried these on a leaf spring front to see how much clearance is between the rotor and passenger side spring? I've seen guys rub their springs using the Toyota/Mazda setup.
thanks, troy
thanks, troy
Nope, sure haven't. The R and D rigs is MikeyDo5's buggy build which is 4 linked. Outside of that we haven't been able to do alot of mixing and matching.
