az-k5
I got new goodwrench heads, set the cam stock. Got it broke in 2000-3000RPM for 30 mins. Now it won't idle. Will not... At all. It will fire right up and run just fine with some throttle (about 1200 RPM). I have moved the dizzy all over and have it where it runs the smoothest. It behaves the same with the vacuum advance and without the vacuum advance. I put the same q-jet back on it that was on it a week ago.
I went from a stock cam, 882 heads, stock intake to a summit dual grind cam (270 lift), Edelbrock performer intake, and goodwrench heads.
Where should I start looking?
Thanks for dealing with me.
Matt
Matt
