xXamwxxXx
Registered Member
So my brake pedal has been getting worse lately. I go to press on it and I get the air escaping sound and its hard to get to the actual brake. i try to keep a good distance away from whoever is in front of me since the reaction time is slow. What I did was take some pliers and close off the line going from the intake to the booster and pulled the line off the booster with the truck running. plugged the end of the line with finger and let loose pliers and felt suction, rpms go way up if i let my finger off a little. Put pliers back on hose and turn off truck. Pull 1 way valve out of booster and hear air escape. The valve is good i assume. i can blow through it only 1 way. Since everything seems to be working right and the fluid is all full I figure it must be the booster right? I just wanna be sure since its going to be about 80 bucks. Once the pedal gets past the hard spot the brakes work good and hold, its just hard to get to that point. Can anybody tell me if i'm on the right track? thanks.
So if thats the case then what else could cause my symptoms? Brake pedal hardness and air sound. Also If i shut the truck off, pump the pedal a few times,hold down on it and then start the truck the pedal dosent go down like it should. If the truck is on and I push down on the pedal there is some surging of the engine, not much but you can hear it. Another thing is if the truck is off and i start pushing on the pedal when it goes down i can hear some air escaping somewhere around the booster/master cylinder. I would just start taking things apart but my blazer is my 20 mile a day daily driver so I want to get this fixed in one shot. Thanks again.
