uglytruk
- Joined
- Oct 24, 2004
- Posts
- 1,329
- Reaction score
- 0
Mine crapped out, and here's what I found.
There are two different switch styles, but they interchange. It's the steel mounting plate that differs.
One is from a front drive, the other maybe a van.
I ground the rivets off, and used a wood screw in the unused hole in the switch and plate. I shoulda' drilled da plate smaller, so I used a piece of the unneeded plate as a "nut". Then ground off the screw almost flush.
This screw touches the column, so grind it tight.
The switch is adjustable, so get it right!
I
I
