gotta shorten my draglink
Yeah I got a welder but I was trying to stay away from sleveing it. I guess I will go by the metal store tomarrow.
If that's the path you're going to take:
Cut the 3" out of the draglink, angle the cuts so you can get more weld filler in there
Slide the sleeve over the draglink, weld the two pieces of draglink back together
Grind the weld down so the sleeve fits
Weld the sleeve up
Weld the sleeve up
This is how I was going to cut the ends that were to be welded together. I was also going to drill holes in the sleve so I could fill those with welds as well as the ends. How thick of a sleve should I get.
picture.php
Persoanlly, i would not sleeve it. I don't care how good you can weld it will never be as strong. You should do it the correct way and cut the 3" off the end and have someone retap the end for you. Steering and Brakes are two things that you should not goof around with. It could be a deadly result one day if the weld ever failed.
Have you considered calling Stephen Watson and talking to him about it?
I get what you're saying and its generally a good point but if you can manage to pull apart a piece of 1.25" .250" wall tube in tension I will eat my hat ;)
It's doubtful that you'll ever "pull" it apart but if you hit it on something there's a MUCH better chance of bending/breaking it for sure. The welded area would be the weakest link (no pun intended).
Maybe it's just me but i take steering and brakes very seriously especially when it could mean the lives of others or my own if it were to fail.
I would think that it would be almost impossible to hit your drag link on something.
Pretty hard to bash a draglink on anything.
Agreed and I still feel sleeving a draglink is acceptable. That's just my opinion though ;)
I have talked to Stephan and I think I will call him again tomorrow. I don't think its worth saving money to risk losing my ability to steer no matter how unlikely it is. I am going to try to find another machine shop tomorrow to see if they have the correct tap but I doubt it. They will probably want just as much to fix as it would be for a new one.
I am looking for the correct tap to do this myself. The question I have is there different 7/8x18 tap likes tapered and non-tapered? If there is I need a non-tapered correct?
You'll want a tapered tap otherwise you'll play hell getting it started. A tapered tap just has the first few threads tapered down some to help get the tap started.
pictures and description
Here are some of the pictures of the process. I think this thing is stronger than it was before. I cut the draglink at a 45* angle and then again to remove 3" from it. I then beveled all the edges to get good penatration. I then slid a 6" piece of tube over the joint and placed both ends in vices. I then slide the tube over, out of the way and welded the draglink back together. Next I cleaned up the weld, removed the 6" tube and installed an 18" piece of 4130 that I had drilled 10 holes in. I lined up the middle holes on the welded joint and then drilled just a little out of the draglink where each hole was. I welded in the holes and welded the end of the tube and then intalled it.
Here is the draglink after I welded it.
picture.php
Here is the 18" piece of 4130 that I drilled holes in.
picture.php
Here is the 4130 installed on the drag link.
picture.php
Here is one of the holes before being welded.
picture.php
Here is one of the holes welded up.
picture.php
And here it is installed.
picture.php
Thanks for all of the input guys!
