Muddytazz said:I've seen some companies use dots instead of lines for their grade markings. Just remember that a grade 8 will have a mark of some kind at every point of the hex head.
It does not always work that way. For example, Deere Co. makes its own hardware and their grade 8 has all the lines coming from a point in the bolt-head center and they radiate out - with none hitting the corners. And, their grade 8 exceeds the usual specs for tensile strength - min. 150,000 PSI tensile strength.
There are several companies that use their own style of grade-marking which I guess gets people confused.
There are also bolts as strong, or stronger with no line markings on the head - e.g. grade 8.1 SAE J429 with 150,000 PSI tensile strength, or ASTM A490 with 170,000 PSI min. tensile strength - but it should have A490 printed on the head. Here's a photo of a Deere Co. grade 8.
I dunno.. do engineers call that something else?
