Grease fittings on 1/2 ton ball joints......
ColAdo82K5
MO
Hey,
I'm pressing new joints into my flattops, and am wondering what to do for the top ball joint grease fitting. It comes with a plug, and the 45degree bend one that is seen in this picture...
http://community.webshots.com/photo/61561424/121637254yQNhNn
But, that fitting doesn't seem to clear the actual axle shaft and u-joint.
What are the opinions and options ?
Blake
Put the zerk in, grease the balljoint, take the zerk out, and put the plug in. That's what I did, and as far as I know, that's all you can do. Just throw one of the grease zerks in your toolbox so next time you've got the front axle torn down you can grease them again.
[ QUOTE ]
[/ QUOTE ]
Yep, thats the way to do it! /forums/images/graemlins/waytogo.gif
My moogs have the upper joint fitting offset to the back (on the beval) and you can leave the greese fitting on all the time with no problems. The spicers I used to have did not have this set up though. /forums/images/graemlins/dunno.gif
Moogs I put in are same as az-k5s...you can leave the zerk in. But, both joints loosened up on me. I thought I had done it right. Why do they loosen up and is retightening the answer? Do they need more torque than the install specs say?
You can also buy a low profile grease fitting that incorporates a spring loaded check ball. They require a special needle in order to grease them. I installed them on my front u-joints so I wouldn't have to do the plug removal thing.
Ran into the same problem. I picked up one of those needle grease gun tips and went around the joint boot. Not sure how well it worked though. /forums/images/graemlins/confused.gif
