OK, I got the front end back together. Put the Zerk fitting on the balljoint before assembly, and once together, realized the fitting end was right between the yokes on the axleshaft joint.
I read past posts, but there has to be a better way. No Moog side greasing joints here, and pulling the axleshaft seems overly complicated for greasing the joint.
The ball joints came with a 45* fitting, and I could hardly get it off with the axleshaft in place. No way I'm getting a grease gun on it.
I see "right angle" grease gun couplers, anyone ever tried one?
http://www.annco.com/products/pro_2.cfm?sku=THE418
Still not sure I could get a fitting on there and make that fit, but who knows.
I'm almost resigned to taking apart the front end to lube it. It's not like it has to be done super often if you don't use the vehicle much, or under rough conditions. Besides, it should come back apart pretty easily. Sigh...
