Is there any way to grease the centering ball on a CV shaft? Both joints are good and the whole unit feels tight but I am getting a little noise from my rear driveshaft. There is no zerk for it so is there anyway to grease it?
If there isn't a grease fitting for a needle you could always use the needle and go through the seal at the ball if you can get to it easy enough (might have to pull the shaft).
