stringer
Newbie
Hello, my name is Will. I am new to Blazers...4x4, and working on vehicles for that matter. This forum has been a great learning resource for me. I have had a lot of fun and fulfillment working on my truck.
I write here to learn. I'm asking for a lot of help.
From what I understand, I am running a 4 inch body lift on 35 x 12.50 R15's - the suspension on my truck feels non-existent. I live in a very flat area and course through dirt roads with many a pot-hole and rut. I'd like to drop my truck down to a 2 or 3" lift and set up a suspension for 35-45 mph travel through pot hole laden, flat sandy/muddy terrain. This truck will see a lot of highway time; I am hoping it can make a 1200 mile round trip every 3 months.
I believe I have a d44 in the front and a 10 bolt in the rear (3.42). I am on the look out at the local junkyards for a 14 Bolt FF rear. I'd like to build one up with 3.73 or 4.11 gears, and a disc brake conversion from GubNi at Pirate4x4 - with the help of some patience, perseverance, the Diff Book 2 and The 14 Bolt Bible; I plan on converting my front axle from 6 - to 8 lugs and 3.73 or 4.11 gears as well.
Taken a look at the shackle flip kit from ORD and have been doing research on Alcan Springs/Bilstein Shocks - wish I could afford coilovers. The problem is, I don't know what I have - much less what I'm doing. May someone please steer me in the right direction - what parts should I be looking at installing for the desired application?
What is going on with these lateral shocks on my front end? I asked a buddy and he exclaimed he'd never seen anything of the sort.
What I'm working with:
I realized that I need 5 posts to hold up pictures. If you wish, you can check out my ph0t0bucket, username: willmow.
Thanks a lot for reading.
-Will
-Will
