You can use a TH400 that came behind the caddy engine ,by removing the super long output shaft and tail shaft installing the shorter 4x4 tail shaft and output shaft..those Chevy to B-O-P adapters work,but moving the trans back even slightly requires spacers between the torque converter bolts and flex plate..which may end up being a weak point--the bolts have to be special length and hardness to survive long..
A 700R4 would likely grenade behind a 500 in short order...by the time you built one up strong enough to handle it,a 4L80E would probably be cheaper--but much more complicated,being electrically controlled...but do-able..
I've researched online how to install a 500 in a GM truck,one site I found years ago showed a guys "Chevrollac" ,a 2wd pickup that he installed a 500 in simply by bolting a hunk of 1/2" steel plate where the factory small block motor mounts bolted to the frame,and that allowed factory Eldorodao motor mounts that use one stud to bolt to the 1/2" thick flat plate...
He said the install was almost "too easy"--it required a seam on the firewall where it met the trans tunnel to be flattened over with a hammer to clear the drivers side valve cover,and he added the stock small block exhaust bolted up to the caddy manifolds with only slight tweaking..he did have to find a rear sump eldorado oil pan & pickup ,that will likely be the hardest part to get reasonably..
I know of several people who installed caddy engines in pickups,we sold every caddilac engine we had at the junkyard quickly--some guys settled for the 425 and 368 engines when that was all we had--BBC engines here are getting scarce (at least carbed ones),and fetch 1000+ bucks easily if they run,period..so the caddy engines became a popular swap seeing more of them were still around..
I "think" some years of the 368 engines came with factory EFI,a throttle body setup I think,I could be wrong though,they may have had a multi-port..--I'm more familiar with the 4 bbl engines like the 68-76 472's and 500's..
I think a good Q-jet tuned right on a stock 500 should be able to deliver 12-14 mpg if driven sanely...tromp on it once though,and a gallon will vanish in a hurry..
