grinder problem (cont.)
BrianDamage said:
be careful with the contact cleaner..it can dissolve sometypes of plastic
LOL it seems nothing is safe for some plastics, it would help if I knew what kind of plastic my grinder was made out of !:doah:
Thanks for the heads up
Ok, I'll bite..
Did you unhook anything inside the grinder when you first took it apart? You said you needed the ring terminals inside... So you did have it apart. Is it possible somethings not hooked up properly. Without seeing a picture, its tough to tell.
Just a thought..:confused:
John
Yeah I had the ring connectors off, so maybe I put the black wire where the white wire goes, and the white wire where the black wire goes? It's a possibility because at the end I had tooken it apart 3-4 times so I might have been inpatient and put it on the wrong side.
I will check that tomorrow.
Thanks
hey Steve, i dropped those in the mail this morn.... who knows when you'll get em up in Cananadaland...:rolleyes:
